Release 2016.39 released. New controls on DmX effect
smeighan
4217 Greenfinch Dr CO 80126
Release R39
Bug fixes. New controls on DMX command. More value curves.
Latest releases are found athttp://nutcracker123.com/nutcracker/releases/] [url]http://nutcracker123.com/nutcracker/releases/[/url]
2016.39 Jun 30, 2016
-- enh (keithsw) Make network setup save button work like the layout panel ... red when it needs saving.
-- bug (dkulp) Fix background brightness setting with OpenGL 1.1
-- enh (keithsw) Add backup when xlights started or show directory changed
-- bug (keithsw) Fix value curve enabling/disabling
-- bug (keithsw) Fix piano and VUMeter reaction to changes in timing marks.
-- enh (keithsw) Add model state settings and effect to control states.
-- enh (keithsw) Add autosave to layout
-- bug (keithsw) Ensure effect settings reset when first selected for dropping if they are different to the current effect. Most effects done.
-- enh (keithsw) Add value curves to Pinwheel, Shimmer, Spirograph, Ripple effects
-- enh (gil) DMX effect automatically determines number of channels to use
-- enh (gil) DMX effect will show node names if defined in place of channel numbers
-- enh (gil) DMX effect now uses value curves to do ramps and works with single color channels
-- bug (gil) Fix SuperStar import for Scenes, ImageActions, and Text when layout is horizontal.
-- bug (gil) Update last preview in effects file when preview is deleted. Also protect against a bad named stored in the file.
