Release 2016.41 released. New options on Fill effect. ability to export effects as video
smeighan
4217 Greenfinch Dr CO 80126
Release 2016.41
New options on Fill effect. New ability to export effects that are on a model as a video file.
Remember there are two links to the releases
old: www.nutcracker123.com/nutcracker/releases
new: www.xlights.org
both point to same place.
2016.41 Jul 22, 2016
-- enh (dkulp) Add pinch-to-zoom on Mac trackpad
-- enh (gil) Add page to new sequence wizard to allow selection of a view or all models.
-- enh (gil) Allow effects to be dropped without timing marks while a timing track is active.
-- enh (gil) Add new options to the Fill Effect: Band Size, Skip Size, and Offset.
-- bug (dkulp) When applying effect presets or key bindings, adjust for the xLights version that was used to create that effect/binding
-- bug (dkulp) Crash when trying to delete the background image
-- bug (dkulp) Strobe node types not working correctly
-- enh (dkulp) Add Left/Right starting locations for Icicles
-- enh (dkulp) Write all data in fseq file direcly in one call instead of copied by frame
-- enh (dkulp) Read from fseq files full frames at a time directly into data buffer instead of by channel
-- bug (keithsw) Fix video drift in auto custom model generation
-- enh (keithsw) Add video export of a models effects
-- enh (keithsw) Add new #x.y format for specifying start channel x = universe, y = channel within universe
-- enh (keithsw) Include xbkp files in log packaging and crash dumps
-- bug (keithsw) Fix handling of multiple e131 universes in a single output
-- enh (keithsw) Add timing track renaming on sequencer window and make it automatically update any effects that were using the timing track
-- bug (keithsw) Prevent illegal characters in model and model group names
-- bug (keithsw) Handle duplicate timing tracks in XML file without crashing
-- enh (keithsw) Add additional columns to models export
-- bug (keithsw) Fix test tab handling of models which are single node but multiple nodes such as DMX model
-- enh (keithsw) Add count of effect layers on presets window
