Release 2016.44 released. color curves,Shift+MouseWheel will now scroll grid right/left
smeighan
4217 Greenfinch Dr CO 80126
Latest releases are found atwww.xlights.org] [url=http://www.xlights.org]www.xlights.org[/url]
2016.44 Aug 08, 2016
-- enh (keithsw) Add Import Notes to right click menu on timing tracks ... this will create a timing track containing notes from Polyphonic Transcription, MIDI, Audacity and Music XML files. All sources other than 'Timing Track' will be removed from the piano effect in a future release.
-- enh (keithsw) Enhance autosave to be smarter and only save when it needs to
-- enh (keithsw) Add metronome arbitrary fixed timing timing tracks
-- enh (keithsw) Add color curves
-- enh (keithsw) Add some built in color curves
-- enh (keithsw) Add Timing Event Jump effect to VU Meter
-- enh (keithsw) Make fireworks follow the colour curve
-- bug (keithsw) Fix crashes in music and piano effects
-- enh (gil) Add ability to import/export PolyLine models to .xmodel files.
-- enh (gil) Add ability to PolyLine to create curved segments.
-- enh (gil) Shift+MouseWheel will now scroll grid right/left when in Waveform or Grid. Fixes #644.
-- bug (gil) Fix crashes when switching show directories that contain custom previews.
-- bug (gil) Fix default layer mode not saving for Model Group properties. Fixes #643.
-- enh (gil) Allow multiple selected effects to be moved up/down and nudged left/right. Fixes #642.
-- bug (gil) Fix offscreen effects not moving when dragged or nudged left/right. Fixes #637.
-- enh (gil) Change from Lights/String to Nodes/String based on string type selected. Fixes #633.
-- enh (gil) Allow playback speed to slow down playback for Animation sequences.
