2016.46 Big Release. TreeList in LAYOUT, Sub Models, lots more
Discussion in 'xLights (Nutcracker)' started by smeighan, Aug 18, 2016.
  1. smeighan
    smeighan Dedicated Elf
    Jan 19, 2012
    1,055
    4
    4217 Greenfinch Dr CO 80126
    2016.46 released. This is another BIG release. If people wonder why we do releases every 1-2 weeks it is because our three developers Dan, Gil and Keith, produce so much content.
    - New TreeList in LAYOUT tab from Gil, nice!.
    - Sub models. Look under a model and see new option. This allows taking a snowflake and then defining more models under it. We will prob need a video tutorial on all that this can do.
    - The text effect, that used to have 4 text lines, now has 1. When you open a sequence your text effects will be put on separate layers. This give you more capability than before (for example you can do masking between your individual lines of text now).
    - Lots of SuperStar fixes from Gil.
    - Many bug fixes
    2016.46 Aug 17, 2016
    -- enh (dkulp) Add SubModels for defining effects for specific parts of a model
    -- bug (dkulp) Check for invalid models before adding the models associated with the current view so those models can be selected for mapping
    -- bug (dkulp) Fix node level effect broken in .45
    -- bug (dkulp) Add some null ptr checks and logs to try and prevent/diagnose various crashes
    -- enh (dkulp) More work on enabling sandboxing on OSX
    -- enh (dkulp) Update ffmpeg to new version that doesn't make calls to private API's
    -- enh (gil) Text effect is now 1 line only. Old effects have been split with new layers added when necessary.
    -- bug (gil) Fix window frame rendering when top and bottom sizes don't match. Fixes #599.
    -- bug (gil) Fix arch selection when rotated upside down. Fixes #645.
    -- enh (gil) Support mask settings for Text effect imported from SuperStar.
    -- enh (gil) Add Shimmer option to Pictures effect to support Scene imports with shimmer from SuperStar.
    -- enh (gil) Fix SuperStar import that created upside-down color wash effects.
    -- bug (gil) Fix scene import from SuperStar. Scenes should never be flipped vertically. Also remove FlipY option.
    -- bug (gil) Fix the flipping issue for vertical sequences for SuperStar import. Got broke when fixing horizontal sequences.
    -- bug (gil) Fix copy/paste row that was broken by 2016.43.
    -- enh (gil) Modify row copy/paste to work cross sequence and when Paste by Cell is active. Fixes #650.
    -- bug (gil) Fix Pictures WrapX to wrap at model size instead of image size.
    -- enh (gil) Make the transition smooth if you cancel a model Import. Fixes #647.
    -- enh (gil) Enhance the Layout page by combining the Model Groups and Models.
    -- enh (keithsw) Add model preview to face and state dialogs to make setting channel ranges easier
    -- bug (keithsw) Fix crash when importing fseq when creating a new sequence
    -- bug (keithsw) Fix oversize LCB export. Fixes #648
    -- bug (keithsw) Fix display of tooltips on test tab to display models against channels.
    -- enh (keithsw) Remove all but timing track option for piano effect
    -- bug (keithsw) Strip out video export for models that dont make sense or model groups. Fix colour handling for non RGB colour orders
    -- enh (keithsw) Add simple way to add 7 segment labels to model state definition
    -- enh (keithsw) Add a view from rear option on custom model dialog to help you insert pixels correctly into your coro models Fix #646
    -- bug (keithsw) Fix #u:ch format calc when non e131 controllers are present.
    -- bug (keithsw) Fix accidentally disabled prompt for missing media file.
    -- enh (keithsw) Add state and submodel settings to xmodel files.
    -- bug (keithsw) Fix channel count on models export when channels are not contiguous
    -- bug (keithsw) Trigger start channel recalculation if setup tab is changed ... this helps if you are using o:c or #u:c formats for start channel
    -- enh (keithsw) Add model wiring dialog for custom models ... shows you a reverse view of the model with the wiring.
