Release 2017.30 xLights released. Production Release!
smeighan
4217 Greenfinch Dr CO 80126
2017.30 Released. After 9 months , this is our next Production release! I want to thank the developers for the last month of chasing down all the major bugs and also managing to add quite a few enhancements. If you see a line that fixes or enhances something you really wanted, please thank them.
2017.28 Sep 18, 2017
-- bug (dkulp) Fix crash on startup when ViesModelsPanel is not visible
-- bug (scottH) Fixed Divide by zero error if main window is re-sized too small. (#913)
-- enh (keith) Add ability to import LAS files ... actually this existed ... it just wasnt selectable
-- bug (keith) Add warning if i am importing a datalayer that is bigger than the number of xlights channels
-- enh (keith) Add a xSchedule file play list item which can write information about current song etc to a file
-- bug (dkulp) OSX - Popup menu in "WiringView" dialog is completely disabled
-- bug (keith) Fix crash when change setup and then switch to layout
-- bug (keith) Fix crash when FPP master xschedule step finishes
-- enh (keith) Add creation of a phoneme track from channel data
-- enh (keith) Add model locking
-- bug (keith) Force value curves to update to real values ... it wasnt doing this which may have masked some issues
-- enh (keith) Add row heading tooltips where the model names are too wide to display
-- enh (keith) Add ability to display wiring view from the front
-- enh (keith) Add wiring views for most inbuilt models
-- bug (keith) Validate serial controller number of channels
-- enh (keith) Add ability to extract Phonemes from imported single channel face data
-- bug (keith) Fix timing track labels dont save if added to a fixed timing track
-- bug (keith) Generated submodels leave gaps on large models - overlaps are better than gaps
-- bug (keith) Rename "Output #" column on setup tab to just "Number" to try to address some new user confusion
-- enh (keith) Add optional auto hide show of house preview when playing
-- enh (keith) Add Make master capability to display elements which can take any view and copy its definition to the master view
-- enh (keith) Tag start channels with leading *** where the number has not calculated correctly
-- bug (keith) Prevent duplicate model start calculation errors from displaying
-- enh (keith) Add time display to play controls toolbar on house preview
Gilrock
Tucson, AZ
These are the actual changes for version v30. Sean accidentally posted the v28 release notes.
-- enh (scottH) Added Swap Start and End Points to Morph Effect.
-- enh (keith) Add printing of wiring view
-- enh (keith) Add display of actual time in value curve and color curve dialogs.
-- bug (dkulp) Prevent crash when perspective is chosen from menu prior to flipping to the sequencer tab
-- bug (dkulp) Fix memory leak in JobPool that was leaking thread objects consuming resources
-- enh (keith) Add X and Y axis rotations to rotozoom
-- bug (keith) Fix xlights not opening fseq files
-- bug (keith) Fix zoom value curve not converting correctly
-- enh (keith) Add splash screen courtesy Kevin Pankratz
-- enh (keith) Add ctrl-. and ctrl-/ save and restore position in the sequencer
-- enh (keith) Add crtl-shift 0-9 which jump to 0%-90% through the song in the sequencer
-- enh (keith) Add tags using right click on the timeline ... then use ctrl-0-9 to jump to the tags
-- enh (gil) Add built-in bitmap Fonts that match SuperStar. Not every option works on these fonts but they
do allow the color palette to be used.
-- bug (gil) Fix Convert for LOR files being offset by 1. Fixes #916.
-- enh (dkulp) Optimize loading of test presets to make xLights start quicker
-- bug (dkulp) Hopefully fix crash in CheckSequence if hostname doesn't resolve to local ip address
-- enh (keith) Add new Ctrl left and right arrow and Ctrl Shift left and right arrow shortcuts in sequencer to move and expand effects to timing marks or next effect
-- bug (keith) Fix problem with allocating too few channels if invalid start channels and not enough channels on setup tab
