Release 2017.40 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2017.40 Dec 05, 2017
-- enh (keith) Add support for #universe:startchannel and output:startchannel to all xSchedule fields that define a start channel
-- bug (keith) Fix test dialog tooltips dont display correct models
-- bug (keith) Remove Master View from the new sequence default views
-- enh (dkulp) Add undo to update effect and update palette actions
-- enh (rich) Fix xSchedule web doesnt like spaces in some url parameters #1000
-- bug (scotth) Fix spinner calculate incorrect number of nodes #1008
-- bug (scotth) Fix bulk render doesnt like xml files in subdirectories
-- bug (keith) Ensure all lights are off when xSchedule closes
-- enh (keith) Add active timing marks to Value Curve and Colour Curve dialogs so you can line things up easier
-- bug (keith) Fix xSchedule test mode does not display A-B-C-ALL and some other patterns correctly
  • Like
Reactions: AAH
