2017.41 xLights released
Discussion in 'xLights (Nutcracker)' started by smeighan, Dec 13, 2017.
  1. smeighan
    smeighan Dedicated Elf
    Jan 19, 2012
    1,083
    19
    4217 Greenfinch Dr CO 80126
    2017.41 Released. Thanks to our developers!
    2017.41 Dec 11, 2017
    -- bug (dkulp) Delay actually deleting effects and layers until the end of render to avoid potential crashes.
    -- bug (dkulp) Work on making sure selections are cleared bbefore effects are deleted
    -- enh (dkulp) Add undo to Delete Row Effects
    -- bug (keith) Fix some problems with vertical matrices in xSchedule
    -- enh (keith) Add some fast deleting of effects on a layer/model
    -- bug (keith) Fix a possible race condition when updating effect settings
    -- enh (keith/dkulp) Add model as a pixel render style for model groups ... treats models within the group as a single pixel
    -- bug (keith) Prevent warnings about autosave newer than sequence after batch render
    -- enh (keith) Save selected batch render items between runs of batch render
    -- enh (keith) Add selectable audio devices on windows for xSchedule
    -- bug (craig) Fix the output of the xScheduleData/GetModels.dat file format as json
    -- enh (scotth) Added Tree, Crucifix, Present, Candy Cane, Snowflake, and Heart Shapes to the VU Effect
    -- bug (dkulp) Fix dimming curves that are different for R/G/B
    -- bug (dkulp) Fix debug build popups on rendering on Linux
    -- bug (dkulp) Fix crash on text effect on Linux (fonts still look crappy)
    -- enh (scott) Warn windows 64 bit computer users using 32 bit that they should move to 64 bit
    -- bug (scott) Fix FPP connect wont upload sequences in subdirectories
    -- enh (scott) Add all the shape effect shapes to the VU Meter shape modes
    -- bug (keith) Fix xSchedule text properties not working in API
    -- bug (keith) Fix a number of problems with xSchedule channel constraints not saving
    -- bug (keith) Fix xSchedule fast start audio does not respect per song volume setting
    -- bug (keith) Fix virtual matrices not working reliably or correctly in xschedule
    -- enh (keith) Allow play list buttons like play schedule to work even if a schedule for that playlist is selected
    -- enh (keith) Add delete all effects on a layer or a model
    -- bug (keith) Fix some bugs in calculating pixels for some vertical matrices in xSchedule
  2. the grinch
    the grinch I guess I could use a little social interaction
    Jun 23, 2013
    431
    51
    angle vale s.a.
    Thanks so much guys ! Its truly amazing the efforts you go to ! hats off too you all ! Im stiil on release 17 or thereabouts as I was an early bird this year and haven't wanted too risk anymore updates as everything was set and working perfectly for us ! But truly am looking forward too updating as soon as xmas period is over as I know there has been some huge changes to look forward too .
    Once again thankyou so much xlights team !
    Myself and family wish you a very merry xmas
    Cheers guys
    Wendys likes this.
