Release 2017.45 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2017.45 released. This release mostly has enhancements in it. Again, all thanks go to our developers!
-- enh (craig) Added a randomize current selected effect button
-- bug (craig) Fixed the create random effects to generate random settings
-- enh (keith) Add Open Sound Control (OSC) Master and Remote sync
-- enh (keith) Add Open Sound Control (OSC) sender as a play list item
-- enh (keith) Show layers and layer number in row headings
-- enh (keith) Expand the sizes of matrices xSchedule supports
-- bug (keith) Fix audio override checkbox not set correctly when loaded
-- enh (keith) Show controller status in xSchedule
-- bug (keith) Fix audio send to specified device
-- enh (keith) Add effect setting bulk editing to almost all settings
-- enh (keith) Add horizontal and vertical stack buffer styles for groups ... makes text on groups possible.
-- enh (keith) Show schedule end time when a schedule is running (including any extensions)
-- enh (keith) In xSchedule text optionally suppress text rendering if the text to be rendered is blank ... letting the underlying effect through
-- enh (keith) Add to VU meter "Level Color" and "Timing Event Pulse Color"
-- bug (gil) Fix Shift Effects not shifting effects in collapsed layers. Fixes #1046.
-- bug (gil) Fix Show All Effects not expanding collapsed model layers or strand layers. Fixes #1045.
