Release 2020.46 Released
keithsw1111
Kellyville, NSW
2020.46 November 1 2020
— enh (keith) When xLights has full control allow definition of the default brightness of unused ports
— enh (keith) Optionally link controller tab and layout tab save buttons so both buttons save both files
— enh (keith) Optionally link both upload inputs and upload outputs buttons
— bug (keith) Fix double click on effect deselects effect
— bug (keith) Fix model property change scrolls back to the top of the property list instead of holding position
— bug (keith) Fix model group lists scroll back to the top instead of holding position
— bug (keith) Fix Hanson boards should be opendmx
— bug (keith) Fix clear model controller properties when copied
— bug (keith) Handle material files where the name is not the same as the obj file correctly
— bug (keith) Fix model groups panels lists dont resize with panel
— bug (keith) Fix FPP connect duplicates sequences for upload in some scenarios
As someone who works Lean-Agile in big engineering, your teams' responsiveness is really impressive. Big props
