Release 2021.19 Released
keithsw1111
Kellyville, NSW
2021.19 June 16, 2021
— enh (scott) Added Color Filter To Effect Select Panel
— enh (dkulp) Add end nulls to FPP boards
— enh (keith) Add option to sort views in the same order as the master view
— enh (keith) Add sequence/audio upload to Falcon V4 from FPP Connect
— enh (keith) Provide visual clues that audio device cannot be found as this prevents playback
— bug (scott) Fix Built-in Model to Custom Model Export to minimise missing nodes
— bug (dkulp) Fix custom model background image is black when adjusting brightness
— bug (keith) Further fix to s5 import for channel data
— bug (keith) Fix Pixlite sometimes wont upload configuration
— bug (keith) Fix drag model off port on visualiser does not update screen
— bug (keith) Fix node single colour does not work with custom models
— bug (keith) Fix some groups arches single strand effects not rendering correctly
