Release 2021.25 Released
keithsw1111
Kellyville, NSW
2021.25 August 13, 2021
— enh (dkulp) If the model being imported can be mapped to a vendor supplied xmodel, prompt to use the vendor supplied xmodel.
— enh (keith) Reduce calls to lookup supplier from MAC address by using a local lookup file
— enh (keith) Redo the circle model default render buffer to better handle layers with different numbers of nodes
— enh (keith) Add option to emit MIDI and ArtNET timecode where hour = the step playing. This also works for SMPTE receive
— enh (keith) Show the current position (time) when scrubbing
— enh (scott) Add option to turn off group model missing warning
— bug (gil) Fix Twinkle new render method bug that affected all Twinkles but the first one
— bug (keith) Fix VU Meter volume bars does not fill buffer horizontally
— bug (keith) Fix SMTPE timecode support hidden
— bug (keith) Fix breakdown of phrases/words does not undo correctly
— bug (keith) Fix single strand effect rainbow mode does not work if the first paletter colour is white or black
— bug (dkulp) Fix divide by zero crash in Single Strand effect
