Release 2021.26 Released
keithsw1111
Kellyville, NSW
2021.26 August 25, 2021
— enh (dkulp) Add support for “Virtual Matrix” and “LED Panel Matrix” protocols for Models
— enh (dkulp) Add Virtual Matrix and LED Panel Matrix ports to Visualizer for controllers that support them
— enh (dkulp) Mark the various Pi based hats as being able to support Virtual Matrices
— enh (dkulp) Add a “Pi4 Virtual Matrix” FPP controller type that enables the second HDMI output port
— enh (dkulp) Update FPP output upload to fully configure virtual matrices
— enh (dkulp) Add “Full xLights Control” ability to FPP based controllers
— enh (dkulp) Support multiple virtual matrices per FPP output port (colorlight/linsn sender cards)
— enh (keith) Add check sequence warning for large custom models
— enh (keith) A better way to deal with deciding to map effects due to large numbers of missing models
— enh (keith) Add to check sequence a check for model groups where more than one of the contained models contains the same node
— enh (keith) Add open proxy button to controller tab
— enh (keith) When replacing a model with a model merge the group membership of both models
— enh (keith) Import Lyrix audactity like timing files … xLights will autodetect the lack of tab delimiters and instead use space as a delimiter
— enh (keith) Add lead-in/out to the faces effect when using suppress when not singing.
— enh (keith) Add base support for auto map hints – there is no UI support for this in this release
— enh (keith) When dragging submodel or node effects in the mapping dialog if you hold down the shift key and drop the model onto
a submodel or node with the same node then map all matching submodels/nodes at once
— enh (keith) Add option to purge download cache on xLights startup
— enh (scott) Add start/end nulls to ESPixelStick
— bug (dkulp) If FPP hat/cape supports both pixels and panels, upload configs for both (actually all 3 with VirtualMatrix)
— bug (keith) Fix a falcon with no models but full xLights control does not actually clear all the outputs
— bug (keith) Fix crash in OSC where no path is specified
— bug (keith) Fix crash on startup when using a generic serial output
— bug (keith) Fix inactivating/activating a model does not add/remove <> around model name when applied
— bug (keith) Fix single channel custom model does not render twinkle correctly because the model buffer is not 1×1
— bug (scott) Fix DDP configuring of ESPixelStick V4
@keithsw1111 I see that the Lyrix enhancement also doesn't care about the case of the words anymore.
That was a quick update, well done.
