Release 2021.27 Released
keithsw1111
Kellyville, NSW
2021.27 August 28, 2021
— enh (scott) Add new hinkspix long range support for visualiser and upload
— enh (keith) Strip out further code undermining users free rights to choose their models on windows
— enh (keith) Remove all model group missing models warnings as there is nothing a user can really do about it and several legitimate
ways to trigger it.
— enh (keith) Suppress model faces lead in/out was not working unless you chose to fade
— enh (keith) Show in model properties strands/string as an error if it does not divide evenly into nodes per string
— enh (keith) Dont let the fix files routine look into the backup folder.
— enh (keith) Dont have the backup process follow symbolic links
— bug (keith) Fix cant export presets with & in the name
— bug (keith) Fix channel block and single channel models not represented in visualiser correctly on pixel ports
— bug (keith) Fix multichannel ‘single channel’ custom models not rendering correctly (mostly missing face effects on channels)
— bug (keith) Fix music effect separate not working
— bug (keith) Fix Falcon V4 upload fails for brightness settings the controller does not support
