Release 2021.31 Released
keithsw1111
Kellyville, NSW
2021.31 October 7, 2021
— enh (david) Linux set TCP_NODELAY for OpenPixelControl TCP Output
— enh (jason) Add virtual matrix to pi hat capabilities
— enh (scott) Added purple highlight to State Dialog, Selecting Grid Header will populate all nodes with force color if enabled or white
— enh (scott) Add ArtNet upload to ESPPixelStick V4
— enh (dkulp) Add multi-colour emojis to windows
— enh (keith) Report duplicate nodes in submodels in check sequence
— enh (keith) Add cyan first pixel to 2D as well – disable it for single node models
— enh (keith) Allow selection of gif files in movie effect
— enh (keith) More xScanner enhancements. Recognise more controllers. Faster execution.
— enh (keith) Warn every time xLights starts if the current show folder is in a backup folder
— enh (keith) In check sequence add validations to string start nodes highlighting common errors
— bug (keith) Fix double click on effects at maximum zoom can choose the wrong effect
— bug (keith) For single colour custom models where all nodes only occupy one cell go back to old buffer style
— bug (keith) Fix select effects wont select effects that have no colour selected
— bug (keith) Fix universe per string not updating if the number of channels on controller does not change
— bug (keith) Fix XL font vertical and rotated 90 degree movement
— bug (keith) Fix a crash when loading FSEQ files
— bug (keith) Fix timing panel reverse checkboxes not being reset resulting in weird UI behaviour
— bug (keith) Prevent Pixlite upload sending a group count of 0
— bug (keith) Fix when channel block is first model on a Falcon V4 port an incorrect number of channels are configured
— bug (keith) Allow falcon to upload even when warnings are reported
— bug (scott) Fix layered arch start location
