Release 2021.35 Released
keithsw1111
Kellyville, NSW
2021.35 November 2, 2021
— enh (keith) Allow setting a sefault Virtual Matrix/Video display location used when creating new playlist items
— enh (keith) Add magic words to SMS plugin that can trigger actions
— enh (keith) Update xSchedule FPP ping response to version 3
— enh (keith) Introduce the “No Controller” as the default when adding new models to reduce overlap situations even further
— enh (keith) Start introducing pixielink support
— enh (keith) Make shadow models/models being shadowed visually distinct in visualiser
— enh (scott) Make hinkspix sequence export weave universes like the upload config does
— enh (scott) Add support for smart remote types for controllers
— enh (scott) Add scale but keep aspect ratio to matrix singing faces
— enh (scott) Allow sequence import to load *.piz files without renaming them
— enh (dkulp) Begin introducing use of the Metal graphics API from some screen drawing and effect rendering
— bug (keith) Prevent blank web page being set for xSchedule which looks like web interface is broken
— bug (keith) Adjust Twilio plugin to work with updated API
— bug (keith) Fix error display when F48 is configured with 512+512+1 pixel
— bug (keith) Remove inner % property when star is 1 layer
— bug (keith) Fix layout wiring view does not correctly show missing nodes in custom models
— bug (keith) Fix faces effect wont render if nodes have been renamed after face effect was created with default names
— bug (scott) Fix crash due to _MACOSX folder in zip files
