Release 2022.16 Released
keithsw1111
Kellyville, NSW
2022.16 August 22, 2022
— enh (keith) Allow optional turn off of house and model window docking
— enh (keith) On Falcon and FPP allow definition of zigzag in xlights for upload
— enh (keith) Include controller connection zigzag in xmodel export and import
— enh (ruskin) added an xSchedule command to clear all pixel overlays
— enh (scott) WLED 0.13.2 updates
— enh (scott) Add xmaphint mapping for strands and submodels
— bug (keith) Fix hang if xSchedule is both FPP master and remote
— bug (keith) Fix flash when xSchedule starts video
— bug (keith) Address xLights lagging due to timer issues
— bug (keith) Resize of effect row does not immediately adjust number of rows drawn
— bug (keith) Fix multiselect of state effect corrupts state radio button
— bug (keith) Fix xlDo closexLights does not work
— bug (keith) Fix ugly outline on effect buttons
— bug (keith) Fix xlDo openSequence does not accept sequence name in json
— bug (keith) Fix picture effect warns multiple times that file not valid
— bug (keith) Fix replace model loses group membership
— bug (keith) Fix Falcon FPP upload over wifi not working
— bug (ruskin) Fix “Set pixel range” doesn’t clear pixels when channel count of zero is used
— bug (scott) Adjust x/y locations of FPP virtual display map to the whole preview, not the arbitrary bounding box
— bug (scott) Fix stand rendering with layered arches and stars
— bug (scott) On Hink Pro move DMX after pixels
has the Use OS Font feature been removed ? as text doesn't display if you use it only if you use the other listed fonts in the drop down
