Release 2022.18 Released
keithsw1111
Kellyville, NSW
2022.18 September 28, 2022
— enh (dkulp) Add discovery for new BBShiftString FPP capes
— enh (dkulp) Add upload config support for K128D-B cape
— enh (scott) Support for new HinksPix firmware to support 402 universes
— enh (gil) Improve drawing of 3 point models (Arch, Candy Cane, Icicles) when green square is right of blue square.
Note: If model changes look because it was on a tilt an X rotation with the red rotate handle should fix it.
— enh (scott) Added the ability to scale/offset DMX Values in the DMX Remap Dialog
— enh (scott) Added per model color to DXF file export using the Tag Color
— enh (scott) Added Search Box to SubModel Dialog
— enh (scott) Add Ability to Merge/Copy The Submodels on Replace Model with a Model
— enh (scott) add “${UPPER}” and “${LOWER}” to Text Effect
— enh (scott) Added JSON format import mapping file.
— enh (scott) Added Align Front, Back, & To Ground KeyBindings.
— enh (keith) Add german dictionary to install, user will need to manually add
— enh (keith) Allow shimmer to be suppressed on a face effect
— enh (keith) Allow double click to manually set custom value curve Y values
— enh (keith) Add ability to match video effect duration to the selected video
— enh (keith) Add DMX512P and SJ1221 pixels to Falcon
— enh (keith) Allow renaming of previews
— enh (keith) Aldd option to delete model strand and node effects
— bug (keith) Suppress Tip of the Day if not show folder is set
— bug (keith) More workarounds for image scaling on Windows release builds with MSVC22
— bug (keith) Don’t allow opening of _.xbkp files without renaming
— bug (keith) Fix controller name, advanced config, zigzag for pixlite controllers
— bug (scott) Fix DMX Beam Always On when using Color Wheel
— bug (scott) Fix Package Sequence from automation API
— bug (scott) Fix SubModel Dialog not persisting screen position and size.
— bug (dkulp) Older BBBSerial outputs may have device improperly configured during FPP upload
