Release 2022.19 Released
keithsw1111
Kellyville, NSW
2022.19 October 4, 2022
— enh (keith) Add DMX512P pixel support to Advatek controllers
— enh (keith) Add Advatek v8 protocol support
— enh (keith) Separate Advatek expanded mode support as a variant.
Users who were using expanded mode may need to change variant to upload.
— enh (keith) Add twinkly products as recognised controllers
— enh (keith) Show as an error non selection of controller model
— enh (keith) Give remote falcon users in xSchedule more control over logging volume
— bug (dkulp) Fix issue where model groups dont update until xLights restart
— bug (dkulp) Fix crashes where Fire/Candle effect is used on a submodel
— bug (dkulp) Fix crashes where inactive models are added to groups
— bug (dkulp) Ensure BBB serial output uses the same pinout version as strings
— bug (keith) Possibly address some twinkly start output crashes and if not capture more information
— bug (keith) Fix expanded mode not being set on Advatek boards when it should be
— bug (keith) Fix Twinkly protocol not proxyable via FPP
— bug (keith) Fix not all minleon controllers show the minleon protocols
— bug (keith) Slightly improve visual artefacts on pixture effect on windows due to wxWidgets bug on visual studio
— bug (keith) Fix unnecessary reboot prompt when uploading DDP to F48 V3 controllers
— bug (keith) Fix face shimmer is not frame rate independent
— bug (gil) Fix moving heads dont move smoothly on windows
Hi Keith,
How do you change the variant to utilise the expanded mode on the advetek controllers? I've just updated and all the ports past 16 are now showing as an error in the visualiser.
Just looking at the grab handles on the toolbar sections, perhaps wxWidgets allows closing/moving of sections. I think that you're also missing the stop all button 🛑, which lived in the same section on the 07 and earlier versions.
Can you right click on the toolbar black area and re enable it?
I'll give it a play on my Linux machine tomorrow.
Ive made some props, and i use 3D
now some of the props i have rotated 180deg (to face the opposite way) is there anyway to tell xlights that the frount is the back an vice versa?
one main area i notice this is when looking at the wiring view. (as it display the prop wiring, not its new facing point)
