Release 2023.11 Released
keithsw1111
Kellyville, NSW
2023.11 July 23, 2023
— enh (keith) Make Smart Recievers a more visual component of the visualizer
— enh (keith) Add smart remote tooltip to visualiser
— enh (keith) Fast change smart remote number (and all models on it) by right clicking on the remote in visualiser
— enh (keith) Add smart remote drag/drop in visualiser
— enh (scott) Add Controller Cap and Serial protocol information to automation API JSON
— enh (scott) Add ability to set Model Properties through automation API
— enh (scott) Added Metronome w/ Tags for use with state effect
— enh (scott) Added name support to getControllerPortMap command, added group and models filters to getModels
— bug (scott) Added FPP Proxy IP checks
— bug (dkulp) Attempt to workaround issues on Windows when filenames and FPP Connecte are not in UTF-8 encoding
— bug (keith) Fix incorrect month in log files
— bug (keith) Workaround for Minleon Smart T’s with RGB+ pixels
— bug (dkulp) Fix crash on save if sequence references models that don’t exist
— bug (dkulp) Another attempt to get the controller properies to not rebuild the entire list all the time, prevents crashes
— bug (Pierre Beukes) Fix Moving Head Export: Include slew limits
— bug (dkulp) Fix problems with displaying models with circle/blended circle after changing it on layout page
— bug (dkulp) If resizing/moving/rotating multiple models, make sure the Undo records everything instead of the single selected model
