Release 2023.16 Released
keithsw1111
Kellyville, NSW
2023.16 Oct 9, 2023
— enh (keith) Pre-poulate effect preset rename field with current name
— enh (dartunder) Save/restore test mode tab selection
— enh (keith) Add Find for effect import dialog
— enh (keith) Add a Halloween palette with orange and a purple that look good on pixels without playing with gamma
— enh (dkulp) Import effects – save/restore the “Lock” checkbox value
— bug (dkulp) Fix crash with popup menus on layout panel
— bug (dkulp) FPP Connect – fix hang when uploading to older controllers that use jqupload method
— bug (dartunder) Fix test mode for controller sync enabled with FPP “Player Only”
— bug (dkulp) Possibly fix some audio device crashes when Mac goes into/out of sleep mode
— bug (dkulp) Fix a spurious log warning on file load that was incorrect
— bug (dkulp) Fix some issues of loading sequences always requiring a re-render
— bug (dkulp) FPP Connect – fix detection of some capes that use “v2” pinouts
— bug (keith) Fix “Base layout” apperance in dark mode
— bug (keith) Fix Color Wheel does not always return a feedback color on the UI
