Release 2024.13 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.13 July 14, 2024
– enh (scott) Added “auto shutter” to Moving Head Effect for Color Wheels
– enh (PeteMatthews) ILightThat controllers: Set universe size in config, add Switchy
– enh (scott) Added Undo/Redo to Custom Model Auto Increment
– enh (scott) Added ability to rename controller model name
– enh (keith) Change the packaged sequence default extension to xsqz
– enh (keith) Add ability to directly open packaged sequences from zip/xsqz file in read only mode in xlights by double clicking on zip or dragging it onto the icon
– enh (dkulp) Support for linking Servo effects so that changes to end will effect the start of the next servo and vice/versa
– enh (dkulp) When splitting an effect, use the location of the mouse as the split point (instead of the center)
– enh (keith) For sparse custom models add a save format which is sparse
– bug (cybercop23) Reset all MH Panel options
– bug (scott) Fix some of the Experience SR Upload issues
– bug (scott) Bulk Edit missing in Layout Tab
– bug (scott) If windows hardware video render fails, fallback to software
Status
