Release 2024.17 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.17 October 14, 2024
– change(dkulp) MacOS builds now require MacOS 11 or newer
– enh (dkulp) Resolve hostnames in parallel at startup, much faster startup and FPP Connect
– enh (derwin12) Add key bindings for Jukebox
– enh (derwin12) Add key bindings for increase/descrease speed, prev/next tags
– enh (derwin12) Optionally reverse submodels when reversing models
– enh (thekev) Add support for default gamma with Experience controllers
– enh (dkulp) FSEQ save – allow using more compression blocks for larger channel count sequences
– enh (derwin12) Add validation of in/out fade times
– enh (dkulp) More updates for small waveform time/selection display
– enh (scott) Add support for Wasatch controllers
– bug (derwin12) Fix display of timeline tags, fixes flood of error messages in logs
– bug (derwin12) Fix crash when updating aliases on Strand mappings
– bug (scott) Fix import of “old” moving head models
– bug (scott) Fix HinksPix audio exporting
– bug (scott) Fix DMX moving head advanced export missing parameters
– bug (derwin12) Fix bug flagging versions when importing sequences from the same version
– bug (dkulp) Fix crash on MacOS if monitor with a running preview is disconnected
– bug (derwin12) Fix looping replay of selection not working with audio
– bug (dkulp) Fix crashes on layout panel if protocol not set
– bug (Kyle Grymonprez) Fix “Open Base Show Directory” not working
Status
