Release 2024.20 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.20 December 31, 2024
– enh (dkulp) Performance – if effect backgrounds are turned off, don’t waste time/memory calculating them during render
– enh (cyercop23) Scripting – add command to get fseq dir from preferences
– enh (scott) Controllers – Add V5 Receiver types to K16 controllers
– enh (scott) Add “Degrees” tag to Moving Head model attributes
– enh (scott) Add ability to disable monitorying by default for certain controllers
– enh (scott) New tool to process log files to find recently used show folders
– enh (scott) Sort Backups folder list
– enh (dkulp) Use buffering when writing xml/xsq files to hopefully speed up saving to slow storage (NAS)
– enh (degracode) Bars effect – performance improvement by not recalculating spatial for every pixel
– bug (scott) Model Face dialog – don’t search for face file if the grid attribute is empty (performance)
– bug (dkulp) FPP Connect – fix some issues if FPP has a UI password set
– bug (scott) HinksPix – Make sure Input Mode is set on every upload
– bug (dkulp) Fix some divide by 0 issues in PlasmaEffect, particularly with single line buffers
– bug (scott) Various operations on DMX/MovingHeads can result in Value Curves being deleted
– bug (derwin12) HinksPix – exit upload if SD card selection is cancelled
– bug (keith) xScanner – fix a crash
– bug (keith) xSchedule – fix timecode options needing a restart to take effect
– enh (dev8edss) xSchedule – several RemoteFalcon updates
2
Status
