Release 2025.03 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.03 February 11, 2025
– enh (derwin12) Use ispc on Windows to match Linux and MacOS
– enh (keith) Start adding infrastructure for API/AI driven features
– enh (keith) Experimental support for using AI to map importaed sequences
– enh (MrPierreB) Enhanced HTML “Check Sequence” report
– enh (derwin12) Allow for more than 48 strings for custom models
– enh (derwin12) Use ispc to handle video frame to render buffer transfers
– enh (cybercop23) Add ability to trim audio in sequence settings
– enh (derwin12) Use case insensitive compared when handling import mappings
– bug (dkulp) Fix rendering of brightness and 2 is unmask with ispc rendering
– bug (dkulp) Fix Shadow 1 on 2, Shadow 2 on 1 blending with ispc
– bug (derwin12) Updates for building Shader UI when effect is changed
– bug (dkulp) Fix rendering of Canvas mode effects if layers are not explicitely selected
Status
