Release 2025.04 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.04 March 7, 2025
– enh (cybercop23) And SubModel name to SubModelDialog title
– enh (derwin12) Rename OK button to “Close” for effect preset dialog
– enh (cybercop23) Support for zipping sequences for upload to latest ESPixelStick
– enh (cybercop23/keith) Several updates/fixes for AI Mapping
– enh (derwin12) Disable effect icon backgrounds and effect indicators during batch render
– enh (cybercop23) Add FPP Connect key binding
– enh (MrPierreB) Add Node Count to Submodel Dialog Window
– enh (cybercop23) Add search support for Layout Group/Model & SubModels
– enh (cybercop23) Flag Keep Channel Number for Wled/EsPixelStick
– enh (derwin12) Add option to Import Effects to convert to ‘Per Model’
– enh (scott) Default Galaxy, Shockwave, and Fan to Scale to Buffer
– enh (derwin12) Allow entering state names in mixed case
– bug (scott) Don’t allow sequence media adjustment options if sequence is an Animation
– bug (derwin12) Fix buffer overflow crash in video effect
– bug (derwin12) Rounding error causing crash and skewed image in Video Effect
– bug (derwin12) Fix the overflow/underflow of Brightness setting
– bug (derwin12) Fix Overflow/Undeflow of Subtractive Function
– bug (derwin12) Fix Wipe, Blend, From Mid Transitions
– bug (derwin12) Fix Up arrow button on Aliases dialog
– bug (derwin12) Wave Effect: Allow wave to reach the Y limit
– bug (cybercop23) Don’t allow Visualization of Inactive/Unassigned Preview items
– bug (derwin12) Fix Import of Cube Model
– bug (cybercop23) Fix apply preset from folders using key bindings
– bug (dkulp) Fix visualize/upload of DMXSkull if eye/color channels become disabled
– bug (dkulp) Fix Model list sorting after list rebuild on Layout tab
– bug (dkulp) Fix potential crash on startup on Linux
– change (dkulp) Cleanup FPP Connect to remove support for deprecated FPP API’s
Status
