Release 2025.06 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.06 June 10, 2025
– bug (derwin12) Add editor Right click options to state dialog
– bug (derwin12) Crash when discovering Falcon v4/v5
– bug (MrPierreB) Correct effect movement with drag selection box
– bug (derwin12) Ensure state item render order
– enh (dkulp) Update to ISPC and wxwidgets
– enh (scott) Add ollama AI api service and refactor
– enh (derwin12) Add abitlity to import color palettes and ui change
– bug (derwin12) Dont mark universe per string controllers dirty on startup
– enh (derwin12) Add right click find/replace in timing tracks
– enh (derwin12) Skill multi string shadow models in check sequence
– enh (derwin12) Add option to add an empty group during an effect import
– enh (derwin12) Add redo to menu and shortcut key
– enh (gstrike) Optionally use color palette in candle effect
– enh (derwin12) Retain spacing when copying states
– bug (derwin12) Crash on dropdown selection in Windows
– bug (derwin12) Poly line not rendering flat in model preview
– enh (dkulp) Converting controller to a variant
– enh (gstrike) Add Bong69 controller
– bug (derwin12) Chromakey fix
– enh (derwin12) Have linked Controller/Layout always done
– enh (derwin12) Add blink length to face effect
– enh (scott) hinkspix upload support
– enh (scott) Fedora 42 updates
– bug (cpinkman) Add pixel size to FPP virtual display map
– enh (keith) Fix up EFL vendor model upload links
– enh (derwin12) Add text labels as a timing track creation options
– enh (derwin12) Add right click reset zoom level
– enh (jasonsomers) Add Solo2Go Controller
– bug (derwin12) Handle printing 3d mesh (house) object
– bug (derwin12) Correctly show the default face placement in layout
– enh (dkulp) Vendor model documentation
– enh (dkulp) xLights Vendor info
– enh (Scott) Code refactor
– enh (Scott) Add warning on ESEQ not used 50ms fps
– bug (derwin12) Handle submodel window size being too large
– enh (keith) Add check sequence for mh group not defined correctly
– bug (derwin12) Centering of multiline xlfont text effect
– enh (keith) Preference for bell on render
– enh (keith) Include dimension in model export
– enh (keith) Use dimensions provided in downloaded models
– bug (derwin12) Wave bug with low number of waves having no movement
Status
