Release 2025.07 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.07 July 17, 2025
– bug (derwin12) Handle cursor up/down the sequencer panel consistently
– enh (derwin12) Split multiple effects via right click
– enh (derwin12) Adding models to group now allows regex filter
– enh (derwin12) Wiring view shows start of strings
– enh (derwin12) Import selected effects now handles submodels
– enh (derwin12) Add default Gamma settings for Falcon controller
– enh (derwin12) Store/restore the display layout size and position
– bug (derwin12) Node layout of start model
– enh (scott) Handle Hinkspix updates and visualiser errors
– enh (dkulp) Compile issues with Xcode 26
– enh (derwin12) Restore the horizontal sash position on layout tab
– bug (derwin12) Fix average layer blending render style
– bug (derwin12) Handle crash when outputs are misconfigured
– enh (scott) Import Model will now match groups via alias if exists
– enh (scott) Added breakdown selected phrases
– enh (ebuechner) Update faces download
– bug (scott) Fix crash with chatgpt services
– enh (derwin12) Add label and tweak Services preference
– enh (derwin12) Add clear all and clear selected to import effects
– bug (derwin12) Fix faces effect where state as an outline was not working
– enh (keith) Use Github as source for face downloads
– bug (derwin12) Bug with Fan and Shockwave setting scale to buffer setting for older sequences
– enh (keith/scott) Updates to underlying libraries libLTC, wxwidgets and Github Actions
– bug (dkulp) Fix UI of color palette button
Status
