Release 2025.09 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.09 September 16, 2025
– enh (dkulp) New “Generate Palette” dialog to use AI to generate a color palette
– enh (dkulp) Add “Apple Intelligence” service provider (palette generation only at this point)
– enh (scott/dkulp) Allow Ollama to generate color palettes
– enh (scott) Bunch of updates/enhancements for HinksPix uploads
– enh (Dom Hodgson) Add Baldrick Input8 Controller
– bug (dkulp) iCloud – make sure xsqz files are download from iCloud before trying to open them
– bug (derwin12) Handle crash with Moving Heads when no path is defined
– bug (derwin12) Don’t allow submodels/faces to be copied to Image types
– bug (derwin12) Check Sequence improperly flagging FPP Player as inactive
– bug (dkulp) Bunch of minor fixes/adjustments for appearance issues on MacOS Tahoe
– bug (derwin12) Fix tab key navigation/completion for various property grids
– bug (derwin12) Remove macOS metadata files from Batch render pick list
– bug (derwin12) FPP Connect – make sure uploaded playlists have the “random” value included in the json
Status
