Release 2025.10 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.10 October 2, 2025
– enh (dkulp) Support ChatGBT for AI Color Palette creation
– enh (dkulp) Warn if “Full Disk Access” is enabled
– enh (scott) Support newer Hinkspix Firmware
– enh (scott) *Internal* – change JSON parser for most places json is used
– enh (derwin12) Use orientation metadata tag for jpg images
– bug (dkulp) Services Test button should depend on enabled services
– bug (derwin12) Remove macOS metadata files from Batch render pick list
– bug (scott) Several Hinkspix configuration issues
– bug (derwin12) Update playlist duration and count during FPP Connect
– bug (derwin12) Support old “master” setting for FPP
– bug (scott) Fix issue with Experience controllers and Dummy Smart Receiver sttrings
– bug (dkulp) Fix crash with scroll wheel navigation on Wavefrom on macOS Tahoe
– bug (dkulp) Fix a crash on macOS if an animation sequence is opened after a music sequence and then the audio device is changed
Status
