Release 2025.12 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.12 November 7, 2025
– enh (scott) Make State choice bulk editable
– enh (scott) Add more scheduling options for HinksPix export
– enh (derwin12) Various UI tweaks to the Restore dialog
– enh (derwin12) LUA Script to time batch rendered sequences
– enh (derwin12) Shorter batch render status line
– enh (dkulp) Faster RenderCache cleanup, closing of sequences by optimizing string -> int
– enh (dkulp) FPP Connect – for massive custom models, just map to horizontal string to prevent overly large memory usage on FPP
– enh (derwin12) Show dates of newer autosave rgb file
– enh (PeteMathews) Update ILT controller config upload
– enh (dkulp) FPP Connect – fseq upload to FPP 9.3+ include embedded sequence details
– enh (MartinMueller) Several updates to ESPixelStick v4 upload
– bug (scott) Fix crash with HinksPix in non Full xLights Control mode
– bug (scott) Fix HinksPix Export not loading saved values
– bug (derwin12) Fix scaling/blurring of singing faces on matrices
– bug (derwin12) Fix sequence version check with three digits
– bug (dkulp) Fix Prepare Audio on Mac to properly create m4a files
– bug (scott) Fix some crashes in ESPixelStick, add more error handling
– bug (dkulp) Fix some crashes in RenderCache/macOS if mmap fails
– bug (dkulp) Fix twinkly output not working
– bug (derwin12) Fix Drag/Drop of imported effect in left list causing colums to get messed up
– bug (derwin12) Fix crash in duplicate effect
– bug (derwin12) MacOS – Fix Face delete dialog was not cancellable
– bug (derwin12) Fix Check Sequence CSS file not loadable on Mac
– bug (derwin12) Fix States being imported multiple times
Status
