Release 2025.13 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.13 December 2, 2025
– enh (o0charlie0o) Prevent accidental resize of effects when clicking on them
– enh (scott) Add json printing to fseq utility
– enh (dkulp) Add K8-Max/Pro, organize all K8-* into a group
– enh (o0charlie0o) Add confirmation for Viewpoint Deletion
– enh (o0charlie0o) Add keyboard shortcuts for dividing timings by predefined intervals
– enh (o0charlie0o) Add subdivided timing track generation feature
– bug (derwin12) Fix crash in Twinkly output if twinkly device is offline
– bug (derwin12) Fix a few potential but rare crashes, null pointer exceptions
– bug (MartinMMueller) Fix some crashes in ESPixelStick uploads
– bug (dkulp) Hopefully fix some symbol resolution issues on MacOS11
– bug (dkulp) Fix some hostname -> IP issues when resolving on background threads
– bug (dkulp) FPP Connect -> Fix some issues if FPP is reachable by both direct IP address as well as via a proxy
– bug (scott) Fix a bunch of issues on Linux related to the File Dialog not returning the proper path
– bug (dkulp) Mostly fix Aspect Ratio scaling of Video effect
– bug (derwin12) Filter Label on VU Meter doesn’t handle lists
– bug (Jason Rodriguez) Update from Base folder not handling multicast controllers
– bug (scott) Remove WLED 510 check, add DDP and RGBW check
– bug (derwin12) LUA Render Script reported wrong time on various OS’s
– bug (dkulp) For various exceptions, make sure xLights actually crashes and generates a crash report instead of silently closing
– bug (dkulp) Fix crash at startup if you take too long to select a show folder.
– bug (dkulp) FPP Connect – Only upload “Active” models to FPP model map
– bug (dkulp) FPP Connect – Fix some ipv6 issues
– bug (dkulp) Make sure mp4 extension is added when exporting videos, don’t crash if extension isn’t there
– bug (dkulp) FIx FPPConnect always uploading media
  • Like
Reactions: AAH
Status
