I disagree. If your cable has three cores and you only need a positive and negative, doubling either should help. This is because voltage drop happens over distances. I generally suggest doubling the negative if you can't double both. If this cable is between the controller and first pixel or if the controller and injection point use the same power supply, the negative will carry slightly more current than the positive. This is because it is used as a reference for the data signal. In addition to this, it is generally more practical to fuse the positive compared to the negative. Fusing would be simpler if you only need to fuse a single wire.
