3D STL Files for several hanson electronic boards
Juddge
Glenmore Park - Penrith Area
The following mount files are available:
  • HE-123 RX v2 – Side Mount for Larger Non-Mean Well Power Supplies
  • HE-123 RX v2 and POWER4 – Combined Side-Profile PSU Mount, with both boards positioned on one side.
  • HE-123 RX v2 – Flat Board Mount, available in four leg-clearance heights.
  • POWER4 – Flat Board Mount
  • Sideways PSU Mounts – Flat Board Style, designed for larger 600 W power supplies with a 50 mm body height, featuring a thicker base for improved stability.
The sideways PSU mounts, HE-123 RX flat board mount and POWER4 flat board mount have all been test-fitted in the smaller enclosure sold by Hanson Electronics and fit perfectly.
Their mounting-hole spacing matches the enclosure’s rear grid, allowing the mounts to be repositioned around the grid while maintaining hole alignment for easy installation.
I Hope these help anyone using the Hanson Electronic Boards, these have made my installs alot easier now.
  • HE-123rx v2 - larger psu side mount.stl
  • POWER4_HE123_combined_PSU_mount.stl
  • HE123_RX_mount_package.zip
  • POWER4_mount_package.zip
  • PSU_mounts_reinforced_6mm - wider psu thatn LRS-350.stl
  • Appreciate
Reactions: AAH
RX2 - larger power supplies.
HE123+Power4
RX2 mount (20mm spacing)
Power4
Power supply mount
Added some pics so people can see what they look like.
Note to anyone using these designs (and other mounting options), I recommend the use of nylon mounting screws as in the case of some mounting holes there is insufficient clearance around the holes to ensure that a metal screw won't short anything out.
i need to use the steel to create the thread in the 3D print supports, nylon is only good after the threads are made with a steel screw, but i have checked, and i use m3 screws but my ones have very small heads that barely grab the holes , they have alot of play in these boards, so i have to manually line them up straight, as the power 4 mostly has 4mm holes and if not lined up will sit to one side and yes the screw head will hit parts outside the screw area , so if your not 100%, use nylon screws as per AAH
  • Like
Reactions: AAH
