Andrew2708
- Dec 12, 2014
Hi all, I am in a learning phase of making a string of lights using pre wired lights such as you see in the link below.
Can you let me know how to make the string from these pre wired lights? Eg how do these connect to each other ? adapters etc so i can plug into a powerboard.
Thanks for you any help you can provide.
Cheers Andrew
Andrew
L125W 20pcs Pre Wired 5mm White Led Lamp Light Set 12V ~ 18V NEW | eBay Australia
Size: 5mm Led, The wire about 20cm(L). Lens Color : Water clear. Light Color: White. Forward current (typ/max): 20mA/30mA.
www.ebay.com.au
Cheers Andrew
Andrew
