5Volt pixel strings.
Stephan
Parkes
Hi all, What do you think is the maximum distance run from controller to first pixel for 5 Volt 2811 pixel strings before you get issues. Cheers
Im working out whether I should use 5 or 12 volt strings for some cluster objects about 15 meters from controller.
damo1271
Adelaide
Hi Stephan. there are two things to consider in the length of the run. the first is voltage drop, the second is signal quality.
Many people will give you different views on the signal length issue. Personally I have had success with 5 -10 meter runs, at other times I have needed null pixels at 3m.
Voltage drop also becomes relevant for long runs as the power wire has a small but finite resistance. With 5 volt pixels you don't have as much 'overhead' to lose in voltage drops on a long run. Voltage drop will depend on the number of pixels you are running.
12V pixels waste more power as heat than 5V so its always a balance. Using a larger gauge wire will help minimise any drops due to wire resistance, or put your power supply closer if possible.
scamper
collie
I have not had a problem with 10 - 15m but I have always used cat5 cable for my pixels.
I also make sure I run large 2 core cable for power injection to alleviate any problems with voltage drop.
I did do a test run with a 20m length of cat 5 cable and didn't have a problem but I have never needed to go that far for my actual display.
darylc
404 darylc not found
It varies significantly by controller in my experience.
I've had the F16v2 go a heck of a long way, 21m or so, the Pixlite go pretty good distances (didn't try them at 21m so hard to say exactly) and the j1sys struggling at 5m.
As usual your milage may vary.
i13
The data is the same for 5V and 12V pixels so yes that should work for getting the signal to go long distances. You may well need to power the lights at their location to get around voltage drop. One way to do this is to use a DC-DC converter to give you 5V where you need it without having an extra power supply.
