- Thread starter
- #16
Final assembly
http://www.moondew.com/pixels/array64/tech.htm#FinalAssembly
moondew said:I have one acrylic panel as a spacer between the LEDs and the diffuser panel. Next I am going to try replacing the spacer acrylic sheet with polycarbonate one. Hopefully it is much stiffer.
Even with the cooling fans there is still too much heat build up when the panel is set to brighter levels. This causes the acrylic to bow out quite a bit as well.
I may also look for an alternative for the diffuser panel as well.
