I am looking to use 9 basic rgb strips as moodlighting. I need them all to change color at the same time. My question is using the products listed below is it possible to connect it together like this.
strip====strip====strip====strip====6 amp per channel controller====8 amp per channel amplifier===
strip===strip===strip===strip===strip
http://www.aliexpress.com/fm-store/701799/209843764-329544925/5m-one-roll-5050-SMD-30LEDs-m-led-strip-waterproof-by-silicon-tubing-and-coating-RGB.html
http://www.aliexpress.com/fm-store/701799/209915969-519176023/IP68LED-constant-voltage-rgb-amplifier-DC5-24V-input-max-8A-3-channel-output.html
http://www.aliexpress.com/fm-store/701799/209915969-490583324/RF-Wireless-Touching-LED-Controller-DC12-24V-input-max-6A-3channel-output.html
I know it will require power injection around every 15 feet. Can you use the same 12v power supply to power all nine strips and the controller and amplifier. Thanks for taking the time to help me. Everyone has already been a big help.
