A New Star
Discussion in 'Lights - Store Bought and Home Made' started by Mm, Feb 15, 2013.
  1. Mm
    Mm Silent Elf
    Dec 15, 2012
    129
    0
  2. Tropical Turkey
    Tropical Turkey New Elf
    Oct 29, 2012
    12
    0
    Mena Creek, Far North Queensland
    Just wondering how big the star is? I'm looking to recycle a multicolour 100- light string to light a corflute star but not sure how many lights I'll need to light a 600mm star
  3. OP
    OP
    Mm
    Mm Silent Elf
    Dec 15, 2012
    129
    0
    measuring from left point to right my star measures 500mm
  4. Tropical Turkey
    Oct 29, 2012
    12
    0
    Cool. Great amount of light from only 5 rgb's
  5. kane
    kane Dedicated Elf
    Dec 23, 2010
    1,033
    9
    The RGB stars I have (which are made of perspex, but same sort of thing) are around the same size (500mm across), and have 17 pixel modules in them (the rectangle modules with 3x 5050 leds).
    They're certainly pretty bright, but not over the top.
  6. DeeJai
    DeeJai Is that Magic Smoke?!?
    Oct 18, 2011
    1,007
    0
    No longer in Radelaide
    17 pixels... WOW!
    I wonder, Mm what 1 pixel in the middle would look like.. atm however at 5 pixels they look great
  7. kane
    kane Dedicated Elf
    Dec 23, 2010
    1,033
    9
  8. OP
    OP
    Mm
    Mm Silent Elf
    Dec 15, 2012
    129
    0
    I have added an extra module. Let me know your feedback.
    https://www.dropbox.com/s/zl634tqwzt8e9sw/6%20RGB%20Star.MOV
  9. kane
    kane Dedicated Elf
    Dec 23, 2010
    1,033
    9
    Looks good in terms of brightness!
    From the video, the light is much brighter around the modules, but that may just be the video.. If that's how it looks in person, one option could be to make the stars thicker, and have the modules further back from the Coro, which should diffuse the light a bit more and give you a more even spread of light.. But really depends on how you want it to look, of course!
  10. fasteddy
    Apr 26, 2010
    6,636
    67
    Good advise and what i was going to ask. i use both methods, either the moduules wedged between two strips so the module is diffussed but still bright or the other method where the corex is far enough away that the light is evenly diffused. Either way works well depending on the effect you are looking for.
  11. OP
    OP
    Mm
    Mm Silent Elf
    Dec 15, 2012
    129
    0
    I did try and double the thickness of the front of the star but it did not defuse the light as well as expected. What did work was when I moved the front further away from the lights. Looks good. Will post a video in the coming days of the updated results.
    Thanks to all that have chipped in with guidance.
    MM
  12. OP
    OP
    Mm
    Mm Silent Elf
    Dec 15, 2012
    129
    0
  13. logandc99
    logandc99 Dedicated Elf
    Jul 13, 2012
    1,151
    74
    I put my sunnies on to watch that video. Bright! :)
  14. Benslights
    Benslights Dedicated Elf Global Moderator Generous Elf
    May 2, 2010
    2,475
    171
    Elderslie
    great to see your hard work coming together Matt. job well done
  15. Christmas on Clarafield
    Christmas on Clarafield Full Time Elf
    Nov 9, 2011
    385
    0
    Melbourne
    Great job. I like the effect they give of a full star when on full brightness but can see the modules as they dim as I think it makes it look lie the star is shrinking when dimming.
