Adding models to existing sequence
Right click the model list in the sequence and select Edit Display Elements from the popup menu.
You have to right click one of the existing models or the timing track.
It would be nice if it also worked when clicking in the blank space below the last model.
There is also a button on the tools bar with three yellow boxes and a yellow arrow going from bottom to top. Open that up and add the model to the master view. Then start adding affects. You can also add the model to an existing group then render and the effects will be applied to the model.
