Advatek Pixlite pixel % intensity
Kaite
Hi Can someone help please.
I only have a basic setup.
I am using Windows 7 and Advatek Assistant V2.3.24
1. Click on Controller in Advatek Assistant
2. Click on Control ( Pixlite Configuration Box ) Pixels per out shown as 170.
3. Check Advanced Box.
4. Change pixel % to 50
5. Click OK
6. Pixlite Configuration Box - Click OK
7. Click Search.
8. Click on Controller.
9. Advanced Box still checked.
10. Pixels per output default back to 1.
If I uncheck Advanced Box, Pixels per output will remain at 170 , but % will default back to 100%
Thanks for any advice in advance.
christmasdave
NSW South Coast
When you’re in advanced changing the brightness, are you also setting the #pixels for each port in use? Because you’re using advanced you’ll need to set this manually (also check the box at the bottom to auto update channels when you do this)
KiwiPhil
Boondall, Brisbane
Yeah if you set to advanced you need to manually configure all the channels or it won't save.
It's simpler to set the prop brightness inside xlights and it will set the controller port when you upload output automatically
