Henedce
- Thread starter
- #16
damo1271 said:When I need an acrylic disk I simply use a hole saw in the drill press. Take the centre drill bit out of the arbor and then you will get a nice round cut out with no hole in the centre. Tip: you need to measure the internal diameter of the hole saw, not the external! You MUST use a drill press if this is going to work and secure the acrylic tightly as there is no centre bit.
PS you will need to file the disc to tidy up the edges. This method isnt perfect!
Exact method I used . Was a slow process for 127 of them but it works
