E
Ewan_Humphrey_LOR
Guest
- Thread starter
- #1
Originally posted September 24, 2009
Hi All,
Looking for an answer from one of our more learned electronic people. With the PC model of LOR board they have spade connectors for the 240V connections, 6.4mm females required to connect. Whilst the output spades are
a reasonable distance apart, the input 'hot' and neutral spades are only a few millimetres apart. From the pictures used in the instructions have the spade covered in 'plastic' to the end of the spade. The spades I have from Dick Smith are not covered fully to the 'end'.
Do I need to use 'covered' female spades to reduce the risk of short circuit, or is the distance on the board OK?
If so, should I cover them with something like the heat shrink cover from Jaycar/Dick Smith do, or should I be using the 'covered' spades?
If I need the fully covered spades, any ideas where to source them from?
Thanks,
Ewan
Hi All,
Thanks,
Ewan
