Kaden
Pixels! I need more pixels!
Matt said:im thinking steve perhaps should have used one of these for his anchor point a little while ago......... hmmmmmmmm
Bazinga!
ѕυ;ρєямαη said:All my strip for the roof is attached too cable tie mounts. After you clean the tile attach it with some silicone then you can mount to them.
YES! As you've found, the silicone won't bond to the adhesive on the mounts.indudio said:Do you remove all the adhesive backing of these so the silicon goes on the plastic?
