Baldrick 8 V2 and ready to run options
You've just seen it here (almost) first. (The first was on https://www.facebook.com/share/p/1D28MK6BXa/). The ILightThat Baldrick 8 V2 has finally dropped. It has all the same specs as the V1.1 but has a 2nd ethernet port on it that allows daisy chaining of boards without needing a separate output on a router or switch for each controller.
With the launch of the B8 V2 I've now got a number of ready to run options. These match the original Ready to Run Baldrick 8 but with some extra options. A 2nd waterproof ethernet connector is available to take advantage of the B8 V2's 2nd ethernet port. The other main option is a 2nd 500W waterproof power supply together with a Power8 and 8 2 core pigtails to allow for power injecting and a massive 1kW potential. That is enough lights at enough brightness to sear your visitors eyeballs
Baldrick 8 RTR power injected -inside.jpgBaldrick 8 V2.pngBaldrick 8 RTR base.pngBaldrick 8 RTR inside.png
