Hi all, I have a problem, I'm sure someone out there can help me out.
I have 5 sets of the big w icicle lights. The plan was to cut off the MF controllers and transformers, and run them through a 6 channel dumb RGB controller at 24vdc. I tested the lights at 24vdc and they worked fine, a little flicker but no problems.
Now that I have wired them into the controller, they are running at around 40% brightness, a few of the strands are at 100%. I tested the voltage coming out of the controller, 24vdc, and tested it at the other end of the lights, the same voltage.
I have no idea what I'm doing wrong, does anybody have any idea what I need to do from here?
Thank you!
Thank you!
