Hi All, Firstly Bulk Buy Rules are here for you to read. https://auschristmaslighting.com/threads/202/
Initial discussions on the PCB can be found here
https://auschristmaslighting.com/threads/1876/
All pricing this time in US Dollars and based on a MOQ of 200 PCB's
This Buy will consist of
PCB - US $1.50
BOM1 - US $2.50
3 x Vertical Entry RJ45 Sockets
8 x 2 Pin 3.81mm Screw Connectors
OR
BOM2 - US $3.50
4 x 4Pin Plug-able Socket and Plug set same as used on the J1SYS ECG Range
Here's a image of the PCB from the design software
PCB is 74mm by 40mm in size
Please post your numbers in the following format
PCB x 100
Bom1 x 100
Bom2 x 0
that way it is clear which BOM you want
All Pricing above is inclusive of All fees including Paypal.
Shipping.
AU Shipping will be calculated on the total weight.
up to 500 Grams - $8.50
0.5 - 3Kg will be $14.00
Orders heavier than this will be calculated at shipping time
International Shipping is based on weight and will need to be calculated at time of shipping
A rough guess is each PCB + Bom will weigh Approx 50 Grams, should be less.
Phil
PCB - US $1.50
BOM1 - US $2.50
OR
BOM2 - US $3.50
PCB x 100
Bom1 x 100
Bom2 x 0
Shipping.
Phil
