Cable pass-through for brick
I recently installed seeds as a semi-permanent install on my roofline and I think I'd like to install a controller in my garage. However, the whole exterior is brick / stone and I don't have access to the space behind / above the soffit. What is the best (most attractive) way to create a passthrough the brick into my garage?InstalledSeedLight_Nearest.jpg
I drilled a hole on the outside and in the garage and put in RJ45 gland. Does the trick nicely
To get access to install, I pulled up a few tiles so I could get my hands in. Could do the same if you have colorbond
T
That's a good idea. I may just have to put a small access panel in the ceiling of the garage so i can route the cables since I don't have attic access.
