Can't get xlights to talk to controller
peterbrown123
HI everyone
I can't seem to get my xlighs to talk to the falcon.
I have logged into the falcon and can do a test my lights and everything works, but when I press output to lights in xlights nothing happens.
Are there any settings that I need to do on Xlights for this to happen.
Going to need more info about your setup. Screen shots of xlights configs and falcon configs might help.
Is this your first show?
Have you had them running before?
Does the test from xlights work?
HI cdjazman
Thanks for your quick reply
Yes this is my first show
No I haven't had them running before.
No the test does not work from xlights.
I have done a test from the falcon and all works fine.
Regards Peter
these will help us figure out the problem. Eg in Xlights, select controllers, select your falcon, then screenshot the config on the RHS.
I'm having same problem with new F16V4 controller.
After about 4 minutes of been connected the connection drops out, F16V2 and F16v3 continue to work.
I have to reboot and it work for a little while and drops out again
Cheers mate, I uploaded newest version last night. It was build 9
I will check again when I get home to see if it worked.
