Colors not correct!
int3grate
Hi. Maybe someone can help me figure this out. I have the following pixels setup in FPP:
Here is everything in XLights:
When I test in FPP, the colors are correct on everything. When I try to sequence in XLights, the colors are incorrect on the two BRG strands in the arches. I've tried changing the strand type in the layout to BRG, but that doesn't change anything:
Any idea what is going on here?
You've set the colour order twice. This means xLights is reversing the data and then FPP is switching it back.
Keep xLights set to RGB nodes in the String Properties section, and only adjust it in the Controller Connection section, which is what gets pushed to FPP when you upload the output.
Since this was titled "Colors not correct" here is a tip.
You might want to tweak the gamma settings on the pixels in xLights to around 2.2 to get a better color rendering when they turn on.
Can you guess which prop had the gamma adjusted on it?
