Combine 2 Power Supplies Question
deblen
Hi,
When one wants to Power Inject with a second power supply of the same voltage, all the information states to not have the positives connected, only the negatives.
If I was to use two 12 volt 350 watt (Chinese) power supplies connected with the positives connected, what would I need to be able to achieve this, or it is not possible.
When I mean what do I need, is there other comments that I might have to solder together from the positives together
Thanks in advance.
Deblen
Are you trying to power only one prop?
You could split the prop into 2 and power each half seperately or use a higher output 12v like a server power supply
Hi, Thanks for the replies.
What I was thinking of was using a 12 fuse fuse board that was rated for 30 amps. Used in vehicle applications. By using smaller fuses I would run one side for one power supply the other for the second, , thus the reason for two power supplies.
Deblen
